2.存储配置
存储是编译的固件是否可刷机的最重要的原因,但存储的更换要修改的地方比较多,因此我们建议的方案就是按照现存的工程仿写需要 Bringup 的开发板
1. SPINAND​
1.1. 型号选择​
SDK 默认支持了几种 SPINAND,编译之前需要确认开发板的型号被选中支持,如果不在支持列表中, 则需要参考 SPINAND 移植指南 进行移植
uboot 和 SPL 分区一般都比较小,开启的 SPINAND 型号过多的话存储容易越界,因此建议只打开需要用到的型号即可
1.1.1. uboot​
通过 make um –> Device Drivers –> MTD Support 选择
(0x240000) Offset of bbt in nand
(0x40000) Range of bbt in nand
[*] Define U-boot binaries locations in SPI NAND
(0x100000) Location in SPI NAND to read U-Boot from
[ ] Support Micron SPI NAND
[ ] Support Macronix SPI NAND
[*] Support Winbond SPI NAND
[ ] Support Winbond SPI NAND CONTINUOUS READ MODE
[*] Support GigaDevice SPI NAND
[ ] Support Toshiba SPI NAND
[*] Support FudanMicro SPI NAND
[*] Support Foresee SPI NAND
[*] Support Zbit SPI NAND
[ ] Support Elite SPI NAND
[ ] Support ESMT SPI NAND
[ ] Support UMTEK SPI NAND
SPI Flash Support --->
UBI support --->
1.1.2. kernel​
kernel 分区比较大,默认打开了 SDK 支持的所有型号,因此不用选择。
1.2. 文件系统​
SPINAND 文件系统采用 UBIFS, 以 demo128_nand 工程为例,编译后生成固件的名称为: d211_xxx_page_2k_block_128k_v1.0.0.img
SDK 也支持 page size 为 4K(很少用到)的SPINAND,需要在工程的配置文件 target/d211/demo128_nand/image_cfg.json 进行配置
"info": { // Header information about image
"platform": "d211",
"product": "demo128_nand",
"version": "1.0.0",
"media": {
"type": "spi-nand",
"device_id": 0,
"array_organization": [
// { "page": "4k", "block": "256k" },
{ "page": "2k", "block": "128k" },
1.3. 分区​
分区信息在 target/d211/demo128_nand/image_cfg.json 中
"spi-nand": { // Device, The name should be the same with string in image:info:media:type
"size": "128m", // Size of SPI NAND
"partitions": {
"spl": { "size": "1m" },
"uboot": { "size": "1m" },
"userid": { "size": "256k" },
"bbt": { "size": "256k" },
"env": { "size": "256k" },
"env_r": { "size": "256k" },
"falcon": { "size": "256k" },
"logo": { "size": "768K" },
"kernel": { "size": "12m" },
"recovery": { "size": "10m" },
"ubiroot": {
"size": "32m", //分区大小为32m
"rootfs": { "size": "-" },
"ubisystem": {
"size": "-",
"ota": { "size": "48m" },
"user": { "size": "-" },
1.4. 固件​
固件的大小要和分区大小相匹配,可以自动适配也可以手工调整
1.4.1. 自动适配​
make menuconfig –> Filesystem images
RootFS images  --->
[ ] UserFS 1 ----
[ ] UserFS 2 ----
[ ] UserFS 3 ----
[ ] Generate burner format image
[*] Auto calculate partition size to generate image //通过分区大小自动生成固件
1.4.2. 手工调整​
通过 make menuconfig –> Filesystem images –> RootFS images 调整
[ ] ext2/3/4 root filesystem
[ ] cpio the root filesystem (for use as an initial RAM filesystem)
[ ] initial RAM filesystem linked into linux kernel
[ ] jffs2 root filesystem
[ ] squashfs root filesystem
[ ] tar the root filesystem
ubi parameter select (spi-nand all type support) --->
[*] ubi image containing an ubifs root filesystem
[ ] Use custom config file
() Additional ubinize options
-*- ubifs root filesystem
(0x2000000) ubifs size(Should be aligned to MB) //固件大小,32M
ubifs runtime compression (lzo) --->
Compression method (no compression) --->
(-F) Additional mkfs.ubifs options
2. SPINOR​
SPINOR 采用 squashfs 文件系统,以 per2_spinor 工程为例, 编译出来的固件为 d211_per2_spinor_v1.0.0.img
SPINOR 的分区信息在 target/d211/per2_spinor/image_cfg.json 中
"spi-nor": { // Media type
"size": "16m", // Size of NOR
"partitions": {
"spl": { "size": "256k" },
"uboot": { "size": "640k" },
"userid": { "size": "64k" },
"env": { "size": "64k" },
"env_r": { "size": "64k" },
"falcon": { "size": "64k" },
"logo": { "size": "512k" },
"kernel": { "size": "5m" },
"rootfs": { "size": "9m" },
// "user": { "size": "-" },
SPINOR 存储一般比较小,在 Linux 系统上进行分区调整比较麻烦,本文档不详细描述
3. EMMC​
EMMC 采用 squashfs,以 demo 工程为例, 编译出来的固件为 d211_demo_v1.0.0.img
EMMC 的接口协议固定,因此不需要进行新器件型号的移植
调整分区大小时,也需要同时调整固件的大小来和分区匹配
3.1. 分区​
分区信息在 target/d211/demo/image_cfg.json 中
"mmc": { // Media type
"size": "4G", // Size of SD/eMMC
"partitions": { // Partition table apply to device
"spl": { "offset": "0x4400", "size": "495k" },
"kernel": { "size": "16m" },
"rootfs": { "size": "72m" }, //分区大小为72M
3.2. 固件​
固件的大小调整通过 make menuconfig –> Filesystem images –> RootFS images 调整
[*] ext2/3/4 root filesystem
ext2/3/4 variant (ext4) --->
(rootfs) filesystem label
(72M) exact size //固件大小为72M
(0) exact number of inodes (leave at 0 for auto calculation)
(5) reserved blocks percentage
(-O ^64bit) additional mke2fs options
4. 成果​
正确的存储配置应该能够成功支持固件烧录
